Honda 400EX problem
Old Jun 10, 2009 | 11:09 AM
budmantom's Avatar
Default Honda 400EX problem
Hey guys I recently purchased a 99 400EX and I'm having a bit of a problem with the choke, the butterfly is closing but the rpm's aren't going up, any idea of what could be wrong?
Thanks for any suggestions/help.
Thanks,
Tom
Old Jun 10, 2009 | 01:09 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
A lot of folks remove the butterfly for better airflow. It is a pumper carb, so I just push the throtle a couple times before a cold start, and that injects raw fuel and primes it so I never even need to use the choke.
Old Jun 10, 2009 | 02:12 PM
budmantom's Avatar
That's intersting but mine still has the butterfly and for the most part I doubt I will be using the choke often(like you) but I do wish I could fix it and get it to idle a bit higher, any idea of what the problem may be?
Old Jun 10, 2009 | 02:20 PM
Bad Mojo's Avatar
How far closed is your butterfly going? Do you have a spare carb. to compare it to?
Old Jun 10, 2009 | 02:26 PM
budmantom's Avatar
It closes all the way (as far as I could see), no spare carb here.
Old Jun 10, 2009 | 04:05 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
You want it to idle higher? When? When it's cold? After it's warmed up?
If you want it to idle higher after it's warmed up, adjust the idle screw.
Old Jun 10, 2009 | 04:13 PM
budmantom's Avatar
I want it to idle higher when I have the choke on, right now the idle doesn't change when I engage the choke.
Old Jun 15, 2009 | 01:21 AM
07bloomfieldb's Avatar
The idle isn't meant to change, the choke makes the fuel richer, to get the engine to run until it's warm.
Old Jun 15, 2009 | 09:18 AM
budmantom's Avatar
Well when I run my bike with the choke on the rpm is the same as when it's off, what do you think is the problem?
Old Jun 15, 2009 | 10:29 AM
Pirate Biker
Limping Rider!
Does it stay running or do you have to keep pressing the throtle to keep it running? When the choke is on.
