Extended Swingarm Question
Old Jun 10, 2009 | 05:35 PM
Jag8723's Avatar
Default Extended Swingarm Question
What size brake lines(do I need a new emergency brake line too?) should I get for my 660 raptor if I get a +4 swingarm and what chain do you recommend would work for that swingarm as well?
Thanks for the help!
Old Jun 10, 2009 | 11:40 PM
91Warrior357's Avatar
27 inch rear brake line i think, and you might need a banshee style tm slider to prevent chain slap, i like the RK and D.I.D. chains.
Old Jun 11, 2009 | 07:21 AM
Raptor450's Avatar
Get rid of the e-brake and cable if you extend the swingarm. Any 520 chain should work, just needs to be 8" longer, I recommend the o-ring style. Any dealer should carry these, or you can add on to your original chain with a short piece of chain and have 2 master links.
Old Jun 11, 2009 | 10:16 AM
Jag8723's Avatar
Thanks for the help. I just want to make sure I get everything I need so I'm not stuck waiting on parts I would need to order.
Old Jun 15, 2009 | 01:31 PM
bigned1904's Avatar
if u are making good power get a sidewinder smart chain. 16k tencle strengh. ive broke most other chains in no time with my 700 the sidewinder is worth every penny they charge.
Old Jun 15, 2009 | 08:49 PM
superyfz350's Avatar
When you get the swingarm, your going to want to leave the chain a little looser than normal because when you sit on it, its going to tighten up because of the geomitry. I would suggest getting a spring loaded chain tensinor so your chain dont get to much slack when you hit any bumps.
wendal
Oct 31, 2017 03:31 AM
bigred20653
Oct 2, 2015 10:05 AM
greg86hd
Sep 16, 2015 12:32 AM
wendal
Sep 15, 2015 01:50 PM
