Stalling ,smoke issue
Old Jun 13, 2009 | 02:14 PM
dollar662's Avatar
Default Stalling ,smoke issue
After using gumout carb cleaner on a 01 sportsman . Things got worse it now starts up but if you push the throttle past 10% it starts to bog out and then dies. ones and awhile I can get it to take off and as long as you dont stop its fine.
A few times when it does stall I get a puff of smoke from the carb and one time it gave me a whine noise and even though I was in H gear (stopped)it made a rev movment as if it was going to go backward then stalled and puff of smoke out of the carb
ANy ideas ??
Thanks
Old Jun 13, 2009 | 02:31 PM
ftwflh's Avatar
Take the carb off the bike and tear it apart and clean it right
Old Jun 13, 2009 | 02:58 PM
dollar662's Avatar
Ok but is that what it sounds like the jerking back,smoke,stalling and bogging the carb needs cleaning ?
Thanks again
Old Jun 13, 2009 | 03:17 PM
ftwflh's Avatar
IF you sprayed carb cleaner into the carb you could have got a chunk into the jets.This is a first step in finding your problem
Old Jun 13, 2009 | 03:33 PM
dollar662's Avatar
one thing I should add is it revs no problem and sounds smooth while pouring sea foam in it
Old Jun 16, 2009 | 07:33 PM
dollar662's Avatar
I emptied the bowl and cleaned it out . and it seems to have resolved the issue
Thanks !
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
Waddell4436
Jul 19, 2015 04:22 PM
Dirtbikemike1
10
Jul 12, 2015 07:22 PM
