banshee help
Old Jun 15, 2009 | 07:22 PM
wheily's Avatar
Default banshee help
ok my freind wants me to work on his 03 banshee he had it serviced at dealer ship and it runs the same as before . here is the problem it has a real bad bog off idle witch he said it pretty much has done cence day one and he also said he wanted to do the carb mod ??? i have know clue what he was talking about so i figured i would ask here. thanks for any help
Old Jun 15, 2009 | 07:49 PM
91Warrior357's Avatar
by carb mod hes prolly talking about removing the TORS (throttle over ride system)
there pieces of crap and cause alot of problems on both blasters and banshees, its the real fugly looking gizmo that is on top of each carb.
Old Jun 15, 2009 | 08:40 PM
superyfz350's Avatar
His carbs are probebly not in sync. He needs to pop off the airfilter so he can see the sliders, then push the gas and see if one side opens before the other. If it does, he has to find a way to adjust it. I got my banshee with the TOR's off and idle screws installed, so I couldent tell you how to adjust it with the TOR's on. The kit is pretty cheap and a must if you are going to do upgrades to the motor and use the stock carbs.
Old Jun 15, 2009 | 09:03 PM
yea best way to sync carbs on a banshee are to take the seat and aircleaners off, and use a carb sync tool, either from a store that sells old vw parts or go here F.A.S.T Racing these things work wonders and will get your bike running very good...i recommend a carb sync tool to ever single person who owns a banshee.....heres an example from wes at bansheehq...http://www.youtube.com/watch?v=8FDcsojwVxc
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
