grinding noise when starting
Old Jun 27, 2009 | 04:45 PM
wolverinekid350's Avatar
Default grinding noise when starting
my wolverine is making a weird noise when i push start and the throttle but if i just push start and not the throttle it fine what is making this sound?
Old Oct 2, 2022 | 09:35 PM
SmokingWIll's Avatar
Unhappy
Hey man did you ever find a solution to this problem? im having the EXACT same issue and cant see anything physically wrong
Old Oct 8, 2022 | 08:32 PM
Alive4KJC's Avatar
Hahah me too! Let a brother know if you found the issue!
it may be a bad solenoid, mine is starting to give out.
Old Oct 8, 2022 | 08:35 PM
i can confirm with certainty it was the one way bearing
it looked fine but had been severely overheated!
swap that out and the bearing in the main crank =) slides on under the flywheel
wolverinekid350
Oct 17, 2009 01:02 PM
broski
Oct 8, 2009 11:36 AM
1ShotScott
Mar 3, 2004 10:28 AM
