Honda Rear End Questions
Old Jul 4, 2009 | 08:42 PM
1997xltlimited's Avatar
Default Honda Rear End Questions
I just put on new brake shoes, bearings, and seal kit trx 300 . The bearing was completely gone. I put it all back together and everything is great. I then read a post about putting grease on the seals and inside the brakes where the pads are. I installed everything but used no grease anywhere. Do I take all apart and grease? If so where should I grease and what type of grease?
thanks
Old Jul 5, 2009 | 10:14 AM
polymite's Avatar
do a search for trx rear brake problems. I found it on this site and it shows you what to grease. I say yes take it all apart again and use water proof grease.
Old Jul 5, 2009 | 10:36 AM
I just found that post, I plan on taking it apart again should be easy this time
Old Jul 10, 2009 | 07:05 AM
fourtraxhonda300's Avatar
Well, I see nothing wrong with using no grease, the barring gets rearend grease, and the brakeshoes wont hold with grease on them..As for the seal.. Grease couldent hurt it, but generally it will get grease from the rearend. (The brakes and everything on mine were COVERED)
Old Jul 13, 2009 | 03:38 PM
not sure I guess any other opinions here?
Old Jul 14, 2009 | 01:23 PM
polymite's Avatar
If you found the diagram I was talking about it will show you where to put the grease....
Yes Honda recomends grease on the seals.
Al
Old Jul 14, 2009 | 01:25 PM
polymite's Avatar
The grease is there to keep out water... water will wipe out the brakes,berings, seals and cost you more in the long run....
Al
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
rcappie4
Jul 10, 2015 04:54 PM
200es
Jul 10, 2015 09:09 AM
Rider252
Jul 6, 2015 03:37 PM
yambam13
Jul 4, 2015 01:49 PM
