Brute Force 750 won't start!
Old Jul 5, 2009 | 02:49 PM
TSauer09's Avatar
Default Brute Force 750 won't start!
Okay. So I have an '05 Brute Force 750 and it will not start. Battery is good, the lights and everything work when the key is on. It turns over, it just won't start. But, usually once you get it started and warmed up, then shut it off, it will start right up the next time. Any ideas to what could be wrong?
Old Jul 5, 2009 | 06:56 PM
smk8er's Avatar
check the spark plug?
Old Jul 13, 2009 | 09:46 AM
KMKjr's Avatar
No offense, but your description is too vague.
Do you have spark and fuel?, is the choke working?, etc.....
Old Jul 25, 2009 | 11:27 AM
tjm666's Avatar
you should get the vavues set and check to see if the choke working to see if it is the choke you could try primming it 3 4 times and if it starts right up it is prob your choke if not the your valves are to tight
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
