polaris 500 clutch
Old Jul 6, 2009 | 05:29 PM
str8_ki11a's Avatar
Default polaris 500 clutch
i have a 1998 polaris sportsman 500 4x4
i recently snorkeled it myself and everything is sealed fine nothing leakes. except the clutch cover.around the gasket. does any one have any ideas how to stop thiss
would silicon work. thats what i been hearing
Old Jul 6, 2009 | 05:42 PM
Some have siliconed, foamed,etc,BUT is a bear to remove cover to change belts,etc! Have had some customers have good results using heavy grade marine grease in channel and along gasket,plus easier to remove cover,BUT use whatever works best for you! Other mudders should give your their recommendations! Good luck OPT
Old Jul 6, 2009 | 06:23 PM
The Kid's Avatar
go with the grease
Old Jul 6, 2009 | 08:27 PM
str8_ki11a's Avatar
where do yall think i get the grese from. like a boat store or something
Old Jul 6, 2009 | 08:35 PM
midcity mudder's Avatar
If it's leaking around the clutch cover replace the gasket that seals it. What happens is that it loses it's seal after a while and from removing the cover several times. For what it cost's I would just purchase the oem gasket that goes there and you'll have no more issues unless you remove the cover over and over again. Putting silicone there your going to swear like a trooper when you go to remove it then you gotta clean it all out again before re-installing. OUCH!
Old Jul 6, 2009 | 08:36 PM
Any marine grade grease will do. Wallworld, auto parts stores,etc
Old Jul 6, 2009 | 08:55 PM
str8_ki11a's Avatar
thanks all of yall for all yalls help. i was riding in mississippi this weekend and riding the creek and sunk in the sand and went up to handle bars. stayed running fine. jus wouldnt really move anywhere cause i got water in the belt. so i should change the belt also. is the stock one the best. i do alot of mudding and creek riding
maxjung
Jul 13, 2015 05:11 PM
clsharky
Jul 13, 2015 02:07 PM
Shifts
14
Jul 13, 2015 08:41 AM
200es
Jul 10, 2015 09:09 AM
Wnthunting
Jul 9, 2015 03:02 PM
