CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
OMW Big-Bore Cylinder vs. Sleeve Kit
Old Jul 8, 2009 | 08:05 AM
Forcefed's Avatar
when your holding the football - people will throw evrything they can at you to strip it away .... including the waterboy at the end of the bench.
Default OMW Big-Bore Cylinder vs. Sleeve Kit
I`d like to know what the benefits are of purchasing one of your big bore cylinders over the 720 sleeve kits typically found on Ebay ?
Old Jul 8, 2009 | 08:43 AM
NateB's Avatar
I have a sleeved cylinder with 10.4 hours on it that im selling. head gasket wont seal... the 730 cylinder should be here today. Just call eric at OMW and he will explain everything to you. wish i would've before i did the 720.
Old Jul 8, 2009 | 09:16 AM
MrHorsepower's Avatar
Pro Rider - Oldham Racing
BUILDS THE FASTEST DS's ON THE PLANET!
Want a hot DS, or maybe one of the fastest DS's on the planet? This is the man to contact!
The main problem with the e-bay kits or any other kit that uses the stock cylinder and a sleeve is material thickness. The factory cylinder is NOT designed to be bored out and have a sleeve installed. Once its bored out for the 105mm sleeve kit there is about .080 wall thickness before you break into the water jacket. Since the iron sleeve has no material to hold it in place it moves around causing head gasket problems. Its not uncommon to see the factory cylinder crack or warp under these conditions.
My big bore cylinder on the other hand is a brand new casting designed to accept a 105.5mm piston. It is designed after the stock cylinder with several improvements such as reinforced deck and better cooling. It has been tested under some pretty severe conditions and works great.
Old Jul 8, 2009 | 09:54 AM
ROD2009's Avatar
I think team-pami has the cylinders in a bigbore as well if this helps
may try contact them. I am sure it will be nice.
Old Jul 8, 2009 | 10:59 AM
Forcefed's Avatar
I just checked out the Pami stuff for reference purposes & here is what I found.
Cylinder - Piston - Rings & head gasket came to - $ 1564.00
U.S Dollar vs Euro exchange rate today is .713 add $ 448.86
19% German VAT - add $ 392.44
Brings a total of - $ 2395.30 !
This does not include shipping from Germany. + $ ??
Nor does it cover having to pay for your cases to be machined to accept the cylinder - so I have to ship my engine to Germany ?
I noticed on another site that the OMW complete piston/cylinder package is on sale now for only $1200 + shipping all the way from KY.
I could by 2 of the OMW 730 kits for that price & since it is designed as a bolt on package, there is no need for any case machining.
I think i`ll spend my money in the good ol` USA !
Old Jul 8, 2009 | 11:26 AM
SilverBomb's Avatar
SilverBomb has got an Addiction!
Well put Forcefed. Now where can I find $1200?
Old Jul 8, 2009 | 05:43 PM
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
Chris not all the cylinders have to come from OMW. CP industries makes them for us. The casting we are using is base off the Pami cylinder.
I deal with the Germans all the time . I think you have a few of your numbers wrong.
Old Jul 8, 2009 | 10:43 PM
Big Ray 800's Avatar
Has a DS 800 Turbo Nitrous EFI money eating monster!
Take mr horsepowers advice the steel sleeved cylinders will fail sooner or later i run one for about 2 years and the sleeve will slip down causing head gasket problems
Old Jul 8, 2009 | 11:09 PM
ROD2009's Avatar
are the hprcylinders and the omw cylinders the same or did they fall out and now onlyone is around i was reading on another form that the hpr stuff was price'e as well nothing is cheap now days. what kind of motor do you have forcefed are you like a salesman for this guy in KY.
Old Jul 8, 2009 | 11:11 PM
ROD2009's Avatar
what cc would a 105 cylinder be on a ds650 what would one run like in 300ft dirt drags?
