Spoirt 400 engine noise?
Old Jul 9, 2009 | 08:11 AM
Turboman412's Avatar
Exclamation Spoirt 400 engine noise?
Hello everyone, i am in need of some advice, i have a noise in my polaris and its driving me crazy! recently i rebuild the bottom end, all new bearings, seals, ex. it has oil injection removed and a westco piston .030 over. now i have 2 video's of it running if you guys could watch and give me some advice on what you think it is.
Video 1
YouTube - Polaris Running 2
Video 2
thank you
Old Jul 9, 2009 | 05:11 PM
eggenz7's Avatar
did you rebuild the crank too? could be the rod moving around or the piston is slapping...hard to tell tho
Old Jul 22, 2009 | 12:17 AM
mrtwostroke's Avatar
Well first off these things are noisy, that counterbalance shaft. With the gears that drive are load. If you think it is not a rod bearing, or excessive piston clearance. then the next place to look is the counterbalance. One of mine was really loud because the woodruff key and keyway in the gear were wore out causes lots of backlash.
In person I might be able to tell you but that video it's hard.
Put a stock pipe and silencer back on then listen to it again.
Old Jul 22, 2009 | 12:46 AM
scramblerXrated's Avatar
i listened to your videos the best i could, i didnt hear anything out of the ordinary.
BUT,if yours is a 400 sport, chances are, due to its age, the primary clutch needs rebuilt. they have a way of mimicking engine noise quite well when they are worn out. a good way to tell is if the noise goes away when you rev the motor.
another place to check is inside the recoil housing. i have heard stories of things coming loose inside there and causing quite a ruckus.
X
greg74
Sep 10, 2019 03:03 PM
ronnierhino06
Nov 9, 2015 12:56 PM
hondarider1234
Jul 21, 2015 11:53 PM
ghost civic
Jul 19, 2015 10:13 AM
D-Hagz
Jul 4, 2015 02:19 AM
