Back Brakes
Old Jul 10, 2009 | 08:44 AM
Ragelite's Avatar
Default Back Brakes
When I hit the back brakes, how hard should the feel? I know the front ones grab like mad but the backs seem a little "soft"
Old Jul 10, 2009 | 08:51 AM
scootergptx's Avatar
Supersock
Hired Gun!
The way Polaris designed the rear brakes, they really don't work that well. Not uncommon to have the peddle just go to mush on some. The front brake handle actually works both the front and rear, so you're not really in any danger if the rear pedal does go out.
I've had one Polaris that the pedal needed adjusted once, and was fine. Had another that seemed like you could bleed it every other ride and it would fade. Never leaked fluid, and did it with new pads as well.
Old Jul 10, 2009 | 09:13 AM
TLC's Avatar
TLC
The front stops like mad for two reason, the fronts has 2 disk not just one like the back and the handle also operates the back brake at 40% the other 60% goes to the front.
If I use the back brake pedal alone I can still lock up the back wheels but you have to really stand on it. The back brake is for emergency only if your main brake ever fails.
Old Jul 10, 2009 | 09:17 AM
Supersock
Hired Gun!
Originally Posted by TLC
If I use the back brake pedal alone I can still lock up the back wheels put you have to really stand on it. The back brake is for emergency only if your main brake ever fails.
Even says something to that effect in the owners manuals.
Old Jul 10, 2009 | 09:23 AM
Ragelite's Avatar
That all sounds about right....now that I think about it. Good to know for sure.
Thanks
toonces
Oct 16, 2019 12:11 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 10, 2015 04:54 PM
Coryco
Jul 6, 2015 07:30 PM
