CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
water pump
Old Jul 11, 2009 | 12:34 AM
300lbDSrider's Avatar
Default water pump
I changed my water pump seal due to finding a leak that got progressively worse. Well i started it back up...and still leaking. No water in oil. Any ideas?
Old Jul 11, 2009 | 03:05 AM
SilverBomb's Avatar
SilverBomb has got an Addiction!
Did you check the shaft? If it's a little scored it could cause a leak. Replacing the shaft along with the seals is usually the best way to go.
Old Jul 11, 2009 | 03:49 AM
i did not...i am going to silver lake on wednesday...doubt i can get parts by then, i forgot to put thread sealant on bottom bolt though. I did that and re check after work. had to leave before i could fill it back up to test...thanks for the info
Old Jul 11, 2009 | 07:33 PM
hey silver thanks for the info...it was the shaft and inner seal. A Local bmw dealer had a kit for the f650 so i got it and swapped it out today. Still good to go for the dunes.
Old Oct 1, 2009 | 06:54 PM
kmkustoms's Avatar
is it the same motor
will the kit work
the bmw dealer here has the kit too
i got the oring to replace it since its leaking
but if just replacing it wont help
do i need to replace it all
Old Oct 1, 2009 | 10:09 PM
The kit is the same. I tried replacing the o-ring but it was the inner seal like everyone says. Its a simple job. Just replace it all.
exmotocrosser
Sep 13, 2019 06:12 AM
Alex G.
Sep 11, 2017 11:38 PM
BYC
Sep 25, 2015 02:10 PM
Sw00p
Sep 24, 2015 02:50 PM
