help idle issue 2007 500sp
Old Jul 11, 2009 | 10:05 AM
gemini girl's Avatar
Question help idle issue 2007 500sp
Help, my 2007 500sp has 42 hours and 500 miles, have a problem with holding an idle, machine won't hold idle under 1500 rpms, replaced battery and machine worked, took a test ride, fine pulled back in the driveway atv stalled at idle will now not hold idle.
My husband has been looking at it but he is getting frustrated, I can't get the machine to go into diagnostic even when following the directions is there a trick to it?
I think it might be something as simple as the throttle cable but I am just a female who reads the troubleshooting guide first to try to find a solution.
Anyone experience this problem that could offer any insight? The thought of taking it to the dealer and spending $80 an hour for them to diagnose makes me cringe, we think it is something simple and need a place to start. Its sucks that the warranty is so short on these machines,
Old Jul 11, 2009 | 10:52 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. is it a carb or efi model?
Old Jul 11, 2009 | 11:24 AM
Default low idle
it is EFI HO
Old Jul 11, 2009 | 02:56 PM
#2876315 T-bap sensor harness repair kit could be the answer???.Seems like I've replaced a dozen or so on the 07 models,500 and 700 engines(#2875542).. IF you have ruled out throttle slack at thumb throttle(1/16-1/8" slack) plus no codes,IF trying to activate diagnostic codes on speedo,In neutral key on and off,leave on the third time within 5 seconds,SOMETIMES frustrating to get it to work! But most of the time if T-bap harness has a short it wont throw any codes anyway. Symptoms I usually encounter,NO idle,Sputtering at idle,clears a higher speed, dieing at low speeds,Hard starting sometimes. Hubby can install (has directions on kit) Hope this help OPT
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
MNatv89
Jul 7, 2015 11:36 AM
Sjrpp
Jul 5, 2015 09:04 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
