2004 sp 500ho
Old Jul 11, 2009 | 02:59 PM
rsking45's Avatar
Default 2004 sp 500ho
Hay all,
Im having a problem with my sp500. Not sure if it either electrical of fuel,but leaning towards electrical. Doesnt matter if in high or low when the tach is reading 4200-4700 the motor starts to skip. It happen more often when the motor is under a load. I did adj the ETC and made no difference..I replaced the spark plug, inspected plug wire and its fine.Replaced the fuel filter,air filter is clean. Any ideas?
Thanks
Old Jul 11, 2009 | 03:46 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
no water in the gas is thier?
Old Jul 11, 2009 | 04:13 PM
rsking45's Avatar
Nope no water
Old Jul 11, 2009 | 04:22 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
wonder if maybe a wire shorting out where you said it doesnt do it all the time and its in differnt places of throttle.
Old Jul 12, 2009 | 09:42 AM
rsking45's Avatar
No not all the time but its getting more often that it happens. I am looking to replace the cooling fan. Any idea where I can get a aftermarket one?
Old Jul 13, 2009 | 10:57 AM
Deerkiller's Avatar
Could you be on the rev limiter? Is there a rev limiter?
Deerkiller
Old Jul 13, 2009 | 11:09 AM
02magnum500's Avatar
Gets his share of deer.
check the boot from the carb to the engine, if it has a crack in it they run bad in spots of the rpm range. Mine did that. Just an option.
Old Jul 14, 2009 | 07:32 AM
Kerbbirds's Avatar
Check both vent lines that go from the engine and oil tank to the air box, if either has a hole rubbed in them it will run bad, get replacement fan off ebay, type in polaris fan in atv parts, there is a place that sells direct replacement Spal fans for around $100 bucks.
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
