96 Polaris Xplorer 300 shut off won't crank
Old Jul 11, 2009 | 09:43 PM
FeldaGirl's Avatar
Default 96 Polaris Xplorer 300 shut off won't crank
96 Xplorer 300 was running fine, shut off and will not fire at all. ~battery is good, ~plug is good, ~has power when key is on, ~tried new ign. coil~WILL NOT FIRE~ need your help.
thanks to all who reply
Old Jul 12, 2009 | 05:56 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
when it shut off, did it stop like someone turned off the key and now has no spark at the plug? alaways have ask the stupid question if the kill switch got hit. is the engine turning over when using the key, did you try to start it w/ the pull start to see if it was firing. maybe look for a grounding out issue. the only other would maybe be the stator being bad. imo
Old Jul 12, 2009 | 09:34 AM
FeldaGirl's Avatar
Yes just like you turned off the key~engine turns over~kill switch is on~ tried different stator. No fire from coil
Old Feb 13, 2010 | 06:51 PM
ponchonutty's Avatar
Was this ever fixed and if so, what was the problem?
Sjrpp
Jun 2, 2019 07:25 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
