2007 polaris 500 efi problem
Old Jul 11, 2009 | 09:48 PM
CROOKED STEP's Avatar
Default 2007 polaris 500 efi problem
went out today smelled gas when idling took cap off engine quit and gas sprayed out of filler neck put cap back on got it started once i think battery is shot but would that create the fuel problem
Old Jul 12, 2009 | 02:50 AM
Check your vent tube coming from the fuel tank for kinks or obstructions.If you still smell gas then front cab needs to be removed to check quick disconnect on fuel pump and gasket for seepage. Not a bad idea to trace fuel line all the way to throttle body quick disconnect for any leaks at all! Good luck OPT
Old Jul 12, 2009 | 05:45 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
guessing you have pinched vent line some where letting pressure build up.
Old Jul 14, 2009 | 05:47 PM
thanks i replaced battery found cut vent tube line and alsoadjusted throttle cable seemed to work so far
green giant
Jul 13, 2017 12:07 PM
TJM
Jun 11, 2015 01:28 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
hoopduerr
Jun 1, 2015 08:22 PM
bogie ben
May 30, 2015 04:10 PM
