400 won,t start, help!
Old Jul 13, 2009 | 07:41 AM
r.storey's Avatar
Default 400 won,t start, help!
Have a 2005 400 that will not start, it just turns over. I replaced the plug but still nothing so I pulled the plug and cranked it over and saw no spark at all on the plug, it is gapped at 27 which according to the manual to be correct. It seems like something in the ignition system has quit working, what couls it be?. Thanks for the help.
Old Jul 14, 2009 | 08:47 PM
o2bfst's Avatar
400??? what is it for a 400?
Old Jul 15, 2009 | 04:02 PM
swampyjunior's Avatar
Need a little more info r.storey. Like is is a 400 dvx, 400 TRV, or 400i or act? As each can have a few quirks when losing spark.
Overall, they operate on the same principal of needing spark, fuel and air in the correct ratios to run. Plug gap should be 0.028 - 0.032 inches (0.7-0.8 mm) and be an NGK-CR7E plug type for an AC 400i, ACT and a TRV Not sure about the dvx. Make sure the air filter is clean and that is getting fuel when cranked over. Plug should be wet with fuel.
I have fixed a lot of machines lately that did not run and was assumed "had no spark" in the end it was getting no fuel. You can check by squirting a little fuel in the spark plug hole. Reinstall the plug and turn it over.
Also check that it is in Neutral and that the hand brake is applied if it has the start in gear feature.
Basically need to determine if it is a mechanical issue (clogged carb, bad plug, etc)or electrical issue (pain the rear to find).
SJ
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
