2007 Hawkeye
Old Jul 13, 2009 | 08:36 PM
mazdaman's Avatar
Default 2007 Hawkeye
hi im having a problem locating a couple of the grease fittings. the ones for the Bearing Carrier,and the Transmission upper Pivot point.
Old Jul 14, 2009 | 09:43 AM
Mongrol's Avatar
"Official Site Skeptic"
Its under the upper control arm attachment point on the gear case. Its easier to get at if you undo the upper control arm bolt nearest the wheel and swing the arm up out of the way. Easy to get at. I went through the same search cause the manual diagram is not accurate. This is for the upper trans pivot.
The others are on the uppler and lower part of the bearing carrier. Need a flashight to see them ok.
Sep 23, 2015 06:23 AM
ylomnstr
Sep 22, 2015 12:19 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
snowolson
Aug 31, 2015 03:51 PM
