Sport Quads Discussions on sport quads.
how to eliminate throttle hesitation?
Old Jul 13, 2009 | 11:37 PM
cherokee99's Avatar
Default how to eliminate throttle hesitation?
how do you eliminate throttle hesitation if you blip the throttle quickly? its not enough to bother me, but if i blip the throttle it wont gain any rpm. but if you ease on the throttle like a sane person (while rideing) there is no problem.
Old Jul 14, 2009 | 07:48 AM
Stoopidbot's Avatar
That is your jetting. My R did the same thing at full throttle, get it jetted correctly and that goes away.
Old Jul 14, 2009 | 10:19 AM
ss97's Avatar
Lets Ride!
If the jetting is close, too close to mess with, try the intake insert from Scary Fast called Power Now....it is a metal insert that goes into the intake side of the carb that directs a more concentrated funnel of air into the carb...... I have one on my z400 and you can tell the difference..... It helps a lot at low to mid RPM throttle hits....... I was able to leave my jetting alone when I added a slip-on just because of the Power Now insert......
My buddy also has one on his 400ex and raves about it.....
Old Jul 14, 2009 | 10:44 AM
BEAVER.989's Avatar
Yep, jetting. I was able to fix mine by leaning the pilot circuit a bit with the fuel mix screw. Turn it in 1/4 turn at a time until the problem goes away. If you have to turn it in any more than 1 1/2 turns out, drop down to the next smallest pilot size.
On a side note, be sure to ride the machine 5 min. before making any adjustments to be sure that it is fully warmed up. Don't just let it run a bit and assume it's good enough, it's not. Also, if the problem only occurs in neutral and doesn't show itself while in gear and moving, it's not a problem, it's normal.
Old Jul 14, 2009 | 12:01 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
If it has a pumper carb, perhaps adjusting it will be helpful?
Old Jul 14, 2009 | 02:47 PM
Beastly 3hundo's Avatar
It's a problem all 300ex's have. It's not in the carb, it's the flywheel, the flywheel is too heavy for it's self. I used to have the same hesitation your talking about, then I got it shaved and it cleared right up. Shaving will also give you more top end power and will help it rev quicker.
Old Jul 14, 2009 | 02:51 PM
But they don't make it for the 300ex, if they did I would have gotten one a loooong time ago.
Old Jul 14, 2009 | 05:51 PM
Red Rider
Never thought about that one! I mostly rode my 300 on tight woods trails, and flywheel weight is an advantage where you are lugging the engine down all the time.
Old Jul 14, 2009 | 07:01 PM
ss97's Avatar
Lets Ride!
My bad...... I thought this thread was about a 400ex...... In the words of the great Homer Simpson ...."Doh!"
Old Jul 15, 2009 | 10:31 PM
cherokee99's Avatar
thats ok guyys, thanks for makeing me more aware of the products that are out there, i have an AMR +1000 cdi on my 300 and it definitely makes the top end more fun. my jetting is spot on now. i also had a dead spot in the midrange, once i fixed that no more hesitation!
