1985 fourtrax 250 NEED HELP ON A COUPLE OF THINGS
Old Jul 15, 2009 | 11:31 AM
Mike8623's Avatar
Default 1985 fourtrax 250 NEED HELP ON A COUPLE OF THINGS
I've got a one owner 1985 fourtrax 250 (trx250). my father bought it new. it ran real good until my brother in law decided it needed it carb adjusted. so now it starts and runs real good..........but after running just a bit and putting it into neutral the idle jumps up quite a bit.............how do I go about readjusting the carb......back to normal?
2nd.......it seems like the clutch slips just a little........I did notice that there seems to be an adjustment point under one of the black plastic covers on the right side of the engine......is there a way to adjust the clutch..........it gets rode real easy..........I hardly ever go over 3 mph.............believe it or not...........just fast enough so that my dogs can keep up.
Old Jul 15, 2009 | 11:39 AM
budedm's Avatar
Is that an automatic clutch?
Old Jul 15, 2009 | 11:45 AM
Mike8623's Avatar
Yes it is an automatic
Old Jul 15, 2009 | 12:02 PM
budedm's Avatar
Ok, on my automatic on my 200SX, on the right side case there is a nut with a screw through the middle of it. I loosten the locknut, then screw the screw in until resistance is felt, then unscrew it 1/4 turn and tighten the locknut. Hold the screw while tightening the nut so it stays put.
Old Jul 16, 2009 | 05:28 AM
HondaMechanic's Avatar
Reactant
Mar 30, 2022 02:08 AM
toonces
Oct 16, 2019 12:11 PM
Geolorgist
Jul 26, 2015 09:48 AM
black_thunder
Jul 12, 2015 11:04 PM
