Boot Replacement
Old Jul 15, 2009 | 08:00 PM
Chevra's Avatar
Default Boot Replacement
Im trying to replace a rear boot on my 02 Sportsman. What is the best way of getting the old one off and slipping the new one on? Thanks in advance.
Old Jul 15, 2009 | 09:53 PM
chuck_raduenz's Avatar
read the sticky on cv boots. the no fast/easy way.
Old Jul 15, 2009 | 10:29 PM
Chevra's Avatar
ya i took a look at that one but mine seems to look different then that one.
Old Jul 15, 2009 | 10:34 PM
nkkiegem123's Avatar
Ok, ill read that sticky CV boot. Hope it will work with me.
Old Jul 15, 2009 | 10:44 PM
whats differnt?
Old Jul 15, 2009 | 11:11 PM
Chevra's Avatar
I don't have that snap ring, or if I do I cannot see it. That looks like a newer quad then mine. I've seen where you just tap it off the shaft with a hammer, not having to squeeze a snap ring, is this how mine is then. I just don't want to bang away and break something.
Old Jul 16, 2009 | 12:40 AM
i had a 2000 sportsman. and there the same drive shafts up to about 2004ish, then the clamps and boots changes some what. but there still the same idea. are they an oem drive shaft? if there oem there the same.
Old Jul 16, 2009 | 12:45 AM
Chevra's Avatar
I really have no idea what kind of shaft it is. I just can't find this ring, i dont want to pound on it and have it break the ring.
Old Jul 16, 2009 | 12:49 AM
bigter's Avatar
clean well there should be ring
Old Jul 16, 2009 | 12:56 AM
clean it real well you will find the circlip ring ears. and if you use a rubber hammer you wont brake nothing. but i just spread the circlip and the shaft falls out.
