Paddles on all 4?
Have any of you guys tried this on your Scr400 4X4's? How did it work? Where did you find the front tires? I have a pipe and a clutch kit, so will I have enough power? Does it work that much better? Or should I stick with paddles on back and putting it in 2WD?
been there, did that . I wount do that again!!!!!! If you realy want to I sugest that you can bench press your quad be for a long ride. Its cool having 4 pads but it rips your arms out of the socket. I'l give you something to try to give you an idea. take your chain off put it in four wheel and go but you have to rember you get real good traction with pads.
later
bdscram1
later
bdscram1
Well I sure it causes problems after a while but I saw a Scrambler 400 4x4 at Fun Wheeler Park with paddles on all four corners. It was modified pretty good(pipe,clutch,carb,etc. you name it) and they lined up at the drag lines. Lets just say a couple of 400ex's, banshee, and a DS650 owner were crying like a bunch of babies.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Aug 25, 2015 11:16 PM
