have to pump brakes
Old Jul 19, 2009 | 06:30 AM
David222's Avatar
Default have to pump brakes
I have a 350 big bear. Just replaced the drum brakes. Some of the calibers where stuck, but i made sure they expanded and contracted before putting the drums on. Now iniatially when you apply the brakes you have to pump the lever several times before they work. I have bleed the air out of each side (several refills). did not help. Any suggestions?
Thanks
Old Jul 19, 2009 | 10:11 PM
slopoke76's Avatar
did you run the adjusters up to where the shoes just barley scrubbed? They have to be pretty close due to the fact that the wheel cylinders don't have alot of travel.
Old Jul 19, 2009 | 10:22 PM
Spyd3rV3nom's Avatar
besides adjusting the drums, take the cap off your brake fluid resivoir and make sure the rubber boot inside the bowl is pushed down. If u left that boot up it wont create the right vacuum.
Old Jul 20, 2009 | 06:44 PM
David222's Avatar
Brakes where adj out as far as i could to get the drum on. The rubber boot had to be pushed in everytime i refilled the resevoir.
Old Jul 20, 2009 | 09:12 PM
HeftyLefty's Avatar
Keep fluid in the reservoir at all times, keep the bottom covered with fluid, don't allow to run dry. Use smooth motion when squeezing handles disconnect line from caliper, squeeze handle, don't release-reconnect to caliper-release handle.
HeftyLefty's Avatar
Old Jul 21, 2009 | 01:01 PM
miassmaro98's Avatar
hefty why do you state to disconnect the hose then reconnect please explain bettter
Old Jul 21, 2009 | 07:50 PM
Traildad's Avatar
Thanks
You could have a bad master cylinder or you might need to bench bleed the master cylinder. You say "initially" you have to pump several times. Does that mean it pumps up and then the next time you need to pump it up again? When you bleed them does air come out or just fluid? If you pump them up and hold the lever does it feel firm or spongy and does it fade away if you hold it?
Old Jul 28, 2009 | 05:16 PM
how do u bench bleed the master?
ltrmc02
Aug 22, 2021 02:34 PM
1ArmBandit
Sep 8, 2015 08:59 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
