trx250r 250r, how much tranny fluid
Old Jul 20, 2009 | 03:36 PM
MrJWahl's Avatar
Default trx250r 250r, how much tranny fluid
i have a 1987 250r. how much transmission fluid does it take?
Old Jul 20, 2009 | 06:48 PM
sdm111's Avatar
2 strokes or 4
There should be a bolt on the right side just under and forward of the fill hole. Take it out and fill tilll fluid comes out then put it back in and it's full. Should be about .7 of a quart
Old Jul 20, 2009 | 07:40 PM
MrJWahl's Avatar
i changed the fluid and when i went ti put the bolt back in it would screw in all the ways but not go tight? what can i do to fix this, oh and i cant spin it by hand
Old Jul 21, 2009 | 05:08 AM
HondaMechanic's Avatar
Which bolt is stripped the drain bolt or the check bolt ..
Old Jul 21, 2009 | 10:28 AM
MrJWahl's Avatar
the drain bolt, well its not the drain bolt, its the part where it screws into, but its not leaking on me
Old Jul 21, 2009 | 10:48 AM
sdm111's Avatar
2 strokes or 4
I have the same problem. I bought one of those rubber plugs with the butterfly nut on the bottom from autozone. Haven't had any problems.
Old Jul 21, 2009 | 10:55 AM
MrJWahl's Avatar
so i use the rubber plug instead of the bolt?
Old Jul 21, 2009 | 01:32 PM
sdm111's Avatar
2 strokes or 4
Yeah, bring your reg. plug to match it up. ( I think it's a 14mm plug ) put some oil on the rubber plug so it dosen't stick, stick it up in there and tighten the butterfly nut till it's tight. I do recommend using a new plug each time you change the tranny oil or fluid just to be safe.
Alex G.
Sep 11, 2017 11:38 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Logan Collins
Sep 5, 2015 08:03 PM
