CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
rear wheel bearing blues
Old Jul 20, 2009 | 09:11 PM
baja 03's Avatar
Default rear wheel bearing blues
i have a 03 baja, road it to long with shot wheel bearings. does anyone know what years will interchange? i need the main houseing and the brake and sprocket hubs as well as bearings and seals. over 600.00 from the dealer. thanks for your help.
Old Jul 21, 2009 | 06:57 PM
MrHorsepower's Avatar
Pro Rider - Oldham Racing
BUILDS THE FASTEST DS's ON THE PLANET!
Want a hot DS, or maybe one of the fastest DS's on the planet? This is the man to contact!
The best I remember 2000-2003 will interchange. In late 2003 the sprocket hub was switched over to aluminum to save weight. 2004 and up is a different animal.
I may have a good used setup in the garage. Call me tomorrow at: 270-334-3331
Or click on the link in my signature for any more info you might need.
Old May 26, 2010 | 01:50 AM
brendo907's Avatar
i have a 2003 ds650 baja and my rear bearings are shot so i began to take it apart and i got everything off except the brake disk and what it mounts to, the screws to take the disk off the mount are basically stripped and i can get it part way off but at a certain point it wouldnt go no further and i can spin it with out the axle moving...anyone know what to do? i want to ride this weekend!
Old May 26, 2010 | 08:36 AM
justme23005's Avatar
Rear wheel bearing failures are very common on DS650's. I came up with a kit that uses 2 sealed bearings on each side. I installed my kit on 3 of my DS650's, and haven't had any trouble since. I also use sealed bearings on the front, instead of the open bearings, with separate seals. The part that holds the grease in, on the sealed bearing is steel, instead of rubber, like most sealed bearings. I sell the front kits (enough to do 1 wheel) for $19.95. The rear kits sell for $49.95. They do require modifying the brake & sprocket hubs slightly.
Old May 26, 2010 | 10:34 AM
brendo907's Avatar
ive already ordered the bearings, but i need help taking apart the rear axle...i cant get the drake rotor off...do i need to take the rotor off the mount?
Old May 26, 2010 | 02:41 PM
no, the rotor and hub should just slide off. slide it all the way on, then clean the area near where the big aluminum adjusting nut goes. it should slide right off, with a little help.
Old May 27, 2010 | 09:49 AM
brendo907's Avatar
thanks man, ill see what happens and let ya know
Ean
Dec 19, 2022 08:48 AM
WilliamBos
Jul 13, 2015 02:11 PM
clsharky
Jul 13, 2015 02:07 PM
rcappie4
Jul 10, 2015 04:54 PM
Rider252
Jul 6, 2015 03:37 PM
