2000 praire 4x4
Old Jul 20, 2009 | 09:26 PM
ruike2's Avatar
Default 2000 praire 4x4
i just got a 2000 prarie 4x4 c2 and have to rebuild the drive converter, can anyone tell me in whitch position and how much tention is supossed to be on the spring?
Old Jul 26, 2009 | 11:07 AM
MrSummit's Avatar
I believe you are referring to the driven clutch (closest to rear wheel)
My service manual doesn't state a particular pressure in pounds, but here is what it says:
On the moveable sheave, the spring end goes into hole B.
On the ramp, as you install on the fixed sheave shaft, insert the spring end into hole #2.
Fit the flat portions of the ramp and shaft splines (whatever that means)
Push down the ramp halfway, turn the moveable sheave clockwise 120 degrees and hold it.
Push down the ramp until it is bottomed, and install the spacer and circlip.
Put back the moveable sheave slowly.
Does your primary clutch have any wear? The faces of my sheaves were wavy/grooved after 3,000 miles, and the weights and everything were showing wear so I replaced the whole assy with a Comet.
Jim
Old Jul 26, 2009 | 05:06 PM
ruike2's Avatar
Default thank you
thanks for the help got it back together sounds
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
