Carb tear down and cleaning.
Old Jul 21, 2009 | 09:18 AM
Ragelite's Avatar
Question Carb tear down and cleaning.
Anyone out there have some good detailed instructions on the tear down and cleaning of a carb on a 2004 sportsman 600 twin? Ive never ever in my life touched a carb and this will be a first for me and would like to make sure it goes smoothly if I can. I just want to give it a good cleaning.
Old Jul 21, 2009 | 09:36 AM
TLC's Avatar
TLC
Here is your carb,
The main things to clean are all passages with a wire,and Main jet #11, choke plunger #46 Pilot jet #27 and pilot air jet is #31 I think.
This is instructions for a Slide carb but it still tells you how to clean your 4 main parts just follow step 5 and down.
Disassembly and Cleaning of a Mikuni Round slide Carburetor
Old Nov 28, 2009 | 10:35 AM
polarisbear500's Avatar
a little advice:
TAKE YOUR TIME!!!
also, lay an old towel across your work bench, that way when you take it apart, if something happens to fall out, the towel will catch it. try to remember how you took everything out and be sure to tighten everything when you put it back together. good luck-PB500
Old Nov 28, 2009 | 12:09 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
You do not have to tear the carb apart to clean. Drop bowl, float, jet and spray all passages with cab cleaner followed by presurized air.
Take yor time and work in a clean , clear area so part accountability is easy.
Old Dec 1, 2009 | 06:33 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
What is with the typing........Different country?........Caper.......
Old Dec 1, 2009 | 08:29 PM
Looks like an attack by the Russians?
Old Feb 10, 2012 | 07:49 PM
Me thinks you're in the wrong place! Think you need to make some new friends on Facebook! OPT
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
