Electric Start Problems
Old Jul 21, 2009 | 01:22 PM
Cmat's Avatar
Default Electric Start Problems
I have a 2001 500 manual. The electric start will not work. New battery didn't solve the problem. I can't even jump it. Pull start works fine. A new /charged battery will provide auxillary power to fan, lights etc., but eventually looses its charge. When jumping it, it will click but not turn over. I've had suggestions from the starter, relay switch, selenoid, etc. Any suggestions that might help narrow down what the problem might be?
Old Jul 21, 2009 | 07:44 PM
HeftyLefty's Avatar
Have starter tested, may be bad. Clean relay and solenoid contacts. Clean / test start switch. You may have a voltage leak from a hot wire grounding to the frame somewhere. Grab a cheap voltmeter, and with key, startswitch, and lights off, check for voltage drain at the battery.
If indicated, pull plastics off and check for frayed / bare wiring in harness.
If no leak indicated, pull plastics and start at the pod, trace start / charge circuits back to the battery. Wire can be grounding out even if secured to frame, wrapped in tape, and looking fine to the eye.
Old Jul 22, 2009 | 10:05 AM
swampyjunior's Avatar
I have heard of gunk getting into the starter and binding the brushes. No rebuild kits for the starter either. Just a replacement. I would remove it from the engine laving it hooked up and try it to see what happens OR have it tested.
SJ
Old Jul 22, 2009 | 08:58 PM
carlobee's Avatar
i also do have electric start problems but most of the time it can be fixed with a new battery. but lots of helpful tips here anyway.
4xrider
Apr 10, 2017 01:36 PM
rmx251
Sep 10, 2000 11:40 PM
mrdci
Feb 7, 2000 07:16 PM
mrdci
Dec 4, 1999 11:03 PM
hot_shoe_cv
Oct 13, 1999 02:16 PM
