What size mud tires do you have on your sp500
Old Jul 26, 2009 | 01:06 PM
79hugger's Avatar
Default What size mud tires do you have on your sp500
I'm looking into getting a set of mud tires on my Sportsman,I have a 2" lift but still have the 25" stock tires.My wifes dad has a set of 28" outlaws on his 500 and they do great but he has sacrificed some high range power and keeps it in low range 90% of the time in the mud,I was looking at a set of 26" Super Grip Mud Bitch tires
Old Jul 26, 2009 | 01:35 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
any more then 26" tires and you will loose a fair amount of power and you would need low alot more. 27" will fit w/ no issues, but there again its a power lose. maybe a clutch kit to bring back some of the low end you will loose. you still should be using low in the slow and nasty stuff. imo
Old Jul 26, 2009 | 01:42 PM
700 sportsman's Avatar
agreed I think you would be fine with either 26 or 27's, I would also strongly reccomend the Maxxis Zilla's, they are super lightweight, but great in the mud, I would get 27's in a lighter tire similar to the Zilla's
Also you may want to check out the tire talk section of the fourm over on highlifter.com if you haven't already
Old Jul 26, 2009 | 02:27 PM
TLC's Avatar
TLC
I stayed 25" with the much more aggressive Mud lite XL that way I have more traction yet loose no acceleration or top end speed.
Old Jul 26, 2009 | 06:04 PM
79hugger's Avatar
I was looking at the ITP XL in 27" for additional ground clearance
Old Jul 26, 2009 | 07:28 PM
snipe523's Avatar
Having owned both, I will say get the Zillas over the Mudlites. The Zillas have much better traction even though they have a some what similar tread pattern.
Old Jul 26, 2009 | 10:20 PM
79hugger's Avatar
I guess my next issue is will the 27x9x12 wide Zillas rub up front using the stock rims
Old Jul 26, 2009 | 11:07 PM
TLC's Avatar
TLC
You can get the XXL Mud lites they have even taller/larger lugs then the XLs.
Old Jul 27, 2009 | 07:07 AM
Well if they do, which I believe they will, you would only have to flip the tie rod ends, and then realign, to cure that problem, I haven't personally had to do it, but everyone I've heard that does it never has had any problems
Old Jul 27, 2009 | 09:46 AM
09 popo HO's Avatar
I agree with 700, Go with the 27" Zilla's and flip the tierod's. Once I get a kichen pass from the wife, Thats what I'm doing.
