warrior question
Old Feb 19, 2001 | 07:06 PM
warrior89350's Avatar
I have a 89 warrior that has not been rode VARY hard but it has been rode all of its life. I was woundering if it need a new top end rebuild. if that will make a differance in power. and if any one has a wb cam and a wb piston bored out 30 over and if this means more usable power or just all top end??????? if I just put a high com. piston will it run stronger or what?????
right now it is all stock except the 12 tooth front sprocket.
Old Feb 19, 2001 | 08:14 PM
yamracer's Avatar
I have a warrior with a web cam in it and a wiseco piston. I have it bored 10 over. My neighbor has a warrior also he originally put a white brothers cam in it and he keep tearing it up. the cam shaft broke. So then he went with the web cam and hasnt had a it of problems. His warrior is built a lot more than mine, so I know if the web cam will work good with his then it should work with mine and yours. Just from what I could tell with his the white brothers cam isnt to good, but neither of us has had any problems with our web cams. The web cam helps your power tremendously. You are then able to take everything at a higher gear and that makes you a lot faster. I was running a 12 tooth front but with the cam I had to go up to the factory 13. I hope this information helps!
wendal
May 9, 2024 09:29 PM
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
