It let me down
Old Jul 29, 2009 | 08:36 AM
Spdecat's Avatar
Default It let me down
Well my POPO finally let me down last week I went and volunteered with the local club and when I went to start no go towed out by a Honda . Turns out it broke the flywheel key thus no spark no go it was a $6 buck part but I was not impressed to say the least . I went back again this week the Honda guy was just smiling . Is this a normal part that breaks ?
Old Jul 29, 2009 | 02:54 PM
hddoperator's Avatar
Sorry about your trouble but I don't think it's a common problem. I'm no mechanic by any means, but I read ALOT and don't remember ever seeing the problem before.....
Old Jul 29, 2009 | 08:19 PM
eggenz7's Avatar
sounds like the flywheel nut wasnt torqued when it was last removed. flywheel key only shears if a backfire occurs (has to be pretty strong) or if the nut is loose and the flywheel works itself loose so the crank spins faster than the flywheel causing the key to shear.
Old Jul 29, 2009 | 09:59 PM
war1ock's Avatar
Lucky it didnt do more than jsut shear
Old Aug 2, 2009 | 01:59 PM
Never heard of this problem at all.
Old Aug 2, 2009 | 02:09 PM
UTU's Avatar
UTU
I agree onlyway is if flywheel nut was not torqued/loose....
Old Aug 3, 2009 | 07:29 PM
Spdecat's Avatar
If it was not torqued/loose someone at Polaris must of lost the torque wrench
Old Aug 3, 2009 | 07:36 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
this has happened to a few bikes. some even put set keys in it to advance the timing.
