honda rubicon over heating
Old Jul 30, 2009 | 10:45 AM
rubicon4 20's Avatar
Banned
Default honda rubicon over heating
i was riding my rubicon, and the oil temp light kept coming on, i wasnt riding too hard since it was break in, any answers to what it could be,
Old Jul 30, 2009 | 11:30 AM
faruquehabib's Avatar
what speed were you running, and for how long? how hot was it outside when it came on? did you check the fluid levels?
Old Jul 30, 2009 | 12:04 PM
Turfguy's Avatar
You probably have already done so, but if you haven't:
Make sure the radiator is clean. Get a garden hose all the way up there past the plastic guards and spray it. You will be amazed what can get clogged up in there.
Old Jul 31, 2009 | 07:40 PM
Banned
sive checked the level, ive cleaned the radiator, i think it may just be the quad, it was maybe 70 degrees, id been riding maybe a half an hour 45 min, and driving it pretty easy
Old Jul 31, 2009 | 10:31 PM
Jawsh's Avatar
Did the fan ever kick on? The fan control could be out if it didn't or the the fan motor could be bad or shorting out somewhere on its wires. I've also heard of the control unit that kicks the high oil temp light on can go bad too and cause it to come on even if the oil is at the right temp.
I just reread your original post, I'd check your upper and lower oil coolers for mud and debris, your upper is just into the hood scoop below the front rack and the lower is behind the radiator in front of the fan.
Old Aug 1, 2009 | 04:39 AM
HeftyLefty's Avatar
You say you're in the break in period. Take it to the dealer and let them fix it. Working on it yourself could void your warranty.
Old Aug 1, 2009 | 04:36 PM
JeffinTD's Avatar
A suprisingly small amount of mud or debris in a radiator can cause a liquid cooled machine to overheat.
You can remove the plastic shroud on the side of the radiator to reach in with a hose to spray from the back.
If you haven't done so, check the oil level. To get a correct reading the machine needs to idle (no throttle blips) for about 4 minutes and sit for about 2.
Coolant, check the level both in the plastic bottle, and by actually removing the radiator cap (when the engine is cool).
Beyond that, take it in under warranty. There are two temp sensors (one for coolant and one for oil) and either could be defective, or the computer might not be turning on the fan, or the fan doesn't run...
Old Aug 2, 2009 | 11:09 AM
SpiritOne's Avatar
+1 spray your radiator from behind it. I was having the same problem with my Rubicon, overheating all the time. Spray out that radiator from behind you will be back to 100%.
Old Aug 12, 2009 | 12:01 AM
06bruteforce650's Avatar
or it could be your thermostat when cold if its closed boil water to the temp that causes it to open if it don't open at 210 then u need a thermostat
colt1126
Aug 18, 2015 10:38 PM
cornermike
Jul 30, 2015 06:37 AM
Scottma518
Jul 10, 2015 12:42 AM
