Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
T rex 90
Old Jul 30, 2009 | 06:21 PM
trex90's Avatar
Default T rex 90
i have a t rex 90cc quad..made by madami international llc. i had it running then it died and will not start back up...i can spray a little starting fluid and it will fire but immediately die. i took the carb. to a shop and the mechanic checked it out said it was all good except the float wasnt positioned right, so he adjusted it..told me to try it out..i did and still nothing..i personally think the carb is no good but i dont know...any advice will be helpful..
Old Jul 31, 2009 | 05:03 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum trex90! Id guess the carb is the problem too...Is this a new quad? Used? How long did it run before it died?
Old Jul 31, 2009 | 06:49 PM
trex90's Avatar
it is a 2000 model quad...i had it running for about 30 minutes straight...it ran fine..my mechanic is now saying it could be bad compression or the exhaust being stopped up...but i still think the carb is bad...what do you think?
Old Aug 1, 2009 | 08:44 AM
LT80's Avatar
LT80 Expert
Do a compression test and remove the pipe and blow air thru it. You need to see if those are the problem or not.
Old Aug 1, 2009 | 09:48 PM
trex90's Avatar
compression is reading around 70..exhaust is fine...
Old Aug 2, 2009 | 08:03 AM
KTM Patrol
Former Chinese POW!
70 is not great compression...maybe enough to run but not run well...
