Hand Warmers
Old Jul 31, 2009 | 11:55 AM
Turfguy's Avatar
Default Hand Warmers
I would like to purchase hand warmers for my 2001 Foreman 450 and my 09 Rincon. What have you guys found to be the easiest brand to attach to Honda's. Thanks in advance.
Old Jul 31, 2009 | 02:15 PM
Specta's Avatar
Kimpex
Kimpex Handlebar Grip Heater Kit With Molded Grips | Rocky Mountain ATV/MC
I've had these for a couple of years and been very happy with them.
What ever you get buy an extra relay to power up the grip power relay with the key on.
Old Aug 1, 2009 | 08:42 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
It was 107 degrees there the other day....I can't think about hand warmers......
Old Aug 1, 2009 | 02:22 PM
Turfguy's Avatar
Thanks Specta, anyone else? Deer season is fast approaching.
Old Aug 2, 2009 | 12:26 PM
Specta's Avatar
I'm not going to try and convince you that what I have is the best because I’ve never had anything to compare them too. Several of the folks we ride with have the same set and they too are happy with them.
One of the nice things is that the temperature control is a rheostat so you can set the temp that fits you rather than having only a high and low setting.
I’ve heard other people complain that their’s gets too hot and when they set them on the low setting they just don’t get warm enough.
I would also get some hand guards that will block the wind from your hands and possibly consider a thumb warmer for the throttle. My hand guards were very inexpensive and do a great job of blocking the wind from my hands. 17º and all I wore were my riding gloves.
I have no idea how many different ones that are out there but these seem to work just fine.
This was in Moab Utah Thanksgiving weekend two years ago. It was 17º and we stayed plenty warm.
Old Aug 2, 2009 | 01:34 PM
angler's Avatar
Just last winter I bought some hand warmers and so far I like them. Although I don't do alot of riding in the winter time. On high setting they get too hot. You will probably never have to use the high setting. What I use is called Symtec ATV Winter Pak. It also has a thumb warmer too which makes it extra nice. On the downside, it is kinda pricey. This is similar to what I bought:
Complete ATV Heated "Flexible" Hand Warmer and Thumb Kit w/ 2-Zone Controller
The only thing I see different is mine came with actual heated grips instead of the large square pads.
Hope this helps
Old Aug 5, 2009 | 10:18 AM
JeffinTD's Avatar
106 or so around here also. I wonder if they make handlebar coolers...
Anyway, not much experience with heaters, but I second the handguard/cover suggestion. I put mayer plastic handguards on mine, and even those made a big difference. Just blocking the blast of cold wind really helps.
If I rode much under 20 degrees, then I'd do the heaters too.
Old Aug 5, 2009 | 02:35 PM
Turfguy's Avatar
Angler and Specta, how did each hook up? On my past quad I had one switch for the grips and thumb (I liked that). I got it from the AC dealer specific for AC. It hooked up quickly to wires that were already there for that purpose.
Will these types be similar to that?
Turfguy's Avatar
great pics Specta, as always.
Old Aug 5, 2009 | 04:45 PM
angler's Avatar
On mine I just hooked up directly to the battery, I know I shouldn't have done that. I hate messing with electrical stuff.
Mine has two seperate controls for thumb and the hand grips.
