Couple of maint. questions please
Havnt made it to get a manual yet but figured someone would be kind and help me out. I havnt riden the bike but 1 time and figured before I got to confident with it I better check all the fluids and such to prevent damage. first off:
The front hub oil I take it only uses special Polaris fluid ? I dont have a local dealer so I might have to look for it online somwhere.
how do you know when it is full ? do you rotate it from 12oclock to 3 oclock and let it level itself ?
Does the front gear box take a special fluid as well and how much does it take ?
basicly same questions for the transmission I think I found the fill plug but cant tell where the drain is, maybe because I have a bottom skid plate ? thanks for any help guys.
if you go on polaris web site yo might be able to down load a owners manual that will give you the info you need for your bike. if not someone will give you the correct info for that bike. i think it is 3 oclock that you to be to fill it.
toonces
Oct 16, 2019 12:11 PM
gorylewis
27
Oct 4, 2015 05:22 PM
