How to blink code on Polaris sportsman 600 2004
Old Aug 11, 2009 | 05:53 PM
username's Avatar
Default How to blink code on Polaris sportsman 600 2004
Hi !!!
I have a polaris sportsman 2004 600cc and the check engine light is on!!I try many search but the procedure doesn't work or it's not the good procedure(for blinking the check engine code)!!!!Anyone can help me !?? Please....thanks guys!!!!
Stéphane
Old Aug 11, 2009 | 06:15 PM
mdj104's Avatar
ok,turn the key off,put it in N ,lock the E-brake,wait about 10 secs,hold the rev. override and turn key on.the diagnostig(?) screen will come up and you can scroll with the rev. button.when you find the serv.eng light you can turn it off by holding the rev button a few seconds.
Old Aug 12, 2009 | 09:29 AM
username's Avatar
Thanks!!,But the screen 1 is :battery voltage , screen 2: is: RPM , screen 3: 4WD switch on/off, screen 4: , PRNLH resistive ohms screen 5: wrench icon service, screen 6: selection kmh/mph
Me it's for read the check engine light but I cannot do it on this diagostic mode....If yes , how to make it??..... thanks again!!!
Old Aug 12, 2009 | 05:49 PM
mdj104's Avatar
is it the wrench or SERVICE ENG. ?
Old Aug 13, 2009 | 12:27 AM
username's Avatar
It's the check engine light....not the wrench icon!!!
Old Aug 13, 2009 | 03:46 PM
mdj104's Avatar
ok,key off trans in park.turn key on and off 3 times in 5 seconds,leave key on on 3rd time.the word wait will come up when its searching.record # of flashes.(12 and 61 are the start and end of search).end will come up after last code.
the only bad part is the manual dont tell me what the codes mean.
Old Aug 13, 2009 | 04:17 PM
02magnum500's Avatar
Gets his share of deer.
A 2004 should not even be EFI, They came out in 2005, correct? As far as I know the check engine light only comes on when the engine overheats on a non-efi machine. Maybe there is something wrong with yours. Unless it is an 05 model with efi then there should be codes for the check engine light.
Old Aug 13, 2009 | 11:47 PM
username's Avatar
You have reason!!!........thanks!!!...is my temperature sensor which make my problem?....because I try to disconnect the wire (1 wire only)....the check engine light stay On, and when I connect the wire directly on the engine(ground).....the word hot blink on the dash!!!..But the check engine stay ON always.....another possibility?? thanks again guys!!!
Old Aug 14, 2009 | 08:33 AM
Could you try and disconnect the battery to reset the pod some how??? Not sure if that will do anything but worth a try. If your temp sensor wasn't working it would flash HOT, or if you unplug the fan it should flash HOT. Seems like a pod issue, not sure though.?
Old Aug 14, 2009 | 02:03 PM
username's Avatar
I try 2 times and no result!!!You have the wiring diagram to see which color of wire is the check engine light?
