4x4 question
Old Aug 17, 2009 | 05:40 PM
island hunter's Avatar
Default 4x4 question
I was driving my 03 400 sportsman and all of a sudden the 4x4 kicked in on one side and pulled it hard to the right,the switch was turned off.What would cause this?
Old Aug 17, 2009 | 07:16 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
change the hub fluid. take aparty the hub and clean it and make sure power is getting down to it. you have only one hub engaging is why it pulled hard to the right. a few ideas to try. imo
Old Aug 17, 2009 | 07:17 PM
Usually the armature plate is magnetized on the pulling side from wear or low on fluid. change the fluid first and see if helps. If not I'd replace both sides as the other plate will probably go also,usually fairly quickly! I've done a couple this past week.
Old Aug 19, 2009 | 05:56 PM
the plates are brand new,i will check the fluid level.What gets me is the 4x4 switch was not turned on.
Old Aug 20, 2009 | 06:08 PM
mrtwostroke's Avatar
could be a broken retainer spring
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
