05 400ex head studs
Old Aug 17, 2009 | 08:21 PM
kemper400's Avatar
Default 05 400ex head studs
i have 05 400ex and i want to put heilicoils in it i was wondering if anyone knew the thread pitch, i already know they are 10mm, i want to get the heilicoils before i tear the thing down so it doesnt sit for awhile taken apart.
Old Aug 17, 2009 | 10:15 PM
moto134's Avatar
why? are the threads stripped?
Old Aug 18, 2009 | 08:38 AM
budedm's Avatar
Pretty sure they are 10 x 1.5mm pitch.
Old Aug 18, 2009 | 07:41 PM
mmbintn's Avatar
Get the HD stud kit from GT Thunder. Dont put helicoils in it.
Old Aug 18, 2009 | 08:55 PM
kemper400's Avatar
i need stronger threads not stonger studs though. if i could find the dimensions of the holes in the cylinder i would consider getting The studs. Also what do you do about the hollowed dowl pins in the cylinder and the head with over sized bolts
Old Aug 18, 2009 | 09:01 PM
mmbintn's Avatar
the pins went back over the studs on mine and the threads on the top are standard sized. I know I blew head gaskets on mine till I put the HD studs in it.
Old Jul 10, 2010 | 08:33 AM
DSMRacing's Avatar
This is incorrect. They are 10 x 1.25 pitch. Here's a how-to on repairing pulled out studs.
I used these inserts that I got from Fastenal. I've talked to guys who say that helicoils are fine, but I liked these better.
I also picked up the tap and 31/64 bit I needed while I was there. I got everything for around $40.
First we measured the depth of the existing threads so we'd know how deep to drill.
Then we marked our depth on the drill bit with a piece of tape so we'd know where to stop.
Next, we drilled the holes. Mine is a 440, so the holes were right next to the sleeve. You have to go really slow to make sure that the sleeve doesn't push the bit into the aluminum. Get it close, and then when you start drilling it will center itself on the existing hole. I have had guys tell me that they've drilled them with the jug on the bike using a cordless drill, but I already had mine off so we used the drill press.
Tap the holes, being sure to use plenty of Tap Magic.
The inserts came with some thread locker already on them, but we wanted to make sure they didn't come out.
Thread the inserts in. They go into the tapped holes easy.
There are slots on the top of the inserts that you can use a large screwdriver in to tighten them down.
That's it. It's pretty easy, really. Take your time and there isn't much to it.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
