Motor change ??
Old Aug 25, 2009 | 07:42 PM
coppertop's Avatar
Default Motor change ??
Yes i currently have a 1993 trail boss 350L and 94 400L trail boss,currently just purchase a new cyclinder for the 350 and foudn that piston was gone,so decided to change motors,my 400L runs good but no 4wd somone who had it before me messed the wiring up,so only thing is that my 400 has 8 wires commign from the motor and 350 has 6,but 6 from the 400 look exactly the same wondering can i just cut and macth them up?? i probly will try it anywyas but just lookign for somone with more exsperince to help me out,also if it works should i use the 400L clutches or does it matter? but thx if anyone has information
Old Aug 25, 2009 | 10:07 PM
eggenz7's Avatar
you will have to change the electronics along with the motor. that will make all your wires match up again
Old Aug 26, 2009 | 08:29 AM
coppertop's Avatar
Only problem is that the person who owned it first has all the wiring messed up,because i gues the voltage regalator went on the bike,and he put a totaly different one and messed all the wiring up,basiclly ruin the bike i think
Old Aug 26, 2009 | 09:34 PM
mrtwostroke's Avatar
Well you may be able to use the 350 stator. on the 400. or find some scrambler ignition. because scramblers never had the bigger lighting coil, digital ignition with crank trigger.
Or use the cdi and everything from the 400.
the question is where do the extra two wires go. Is the voltage regulator different. check the online parts fiche and go from there. Do you have a wiring schematic? hmm all check my book and see what I think
Old Aug 26, 2009 | 09:39 PM
coppertop's Avatar
Its 2 wires comming from the magneto the motor,i was basically goin to match 6 that looked alike a give it a try actually
WesTech
11
Aug 11, 2015 07:55 AM
akbrewcrew
Aug 9, 2015 10:54 PM
ghost civic
Jul 27, 2015 03:15 AM
ghost civic
Jul 15, 2015 10:48 PM
