86 honda trx 350 no spark?
Old Aug 28, 2009 | 01:47 AM
trx350guy's Avatar
Exclamation 86 honda trx 350 no spark?
i have a 1986 honda fourtrax 350 4wd. i bought a new coil for it and still no sprak. i thoguht bought buying the ignition controll moudule but i dont know if thats what i need to do.
Old Aug 28, 2009 | 04:28 AM
faruquehabib's Avatar
i believe there are electrical tests in the oem manual for the machine that can be conducted to pinpoint the issue. do you have a manual?
Old Aug 28, 2009 | 09:34 AM
trx350guy's Avatar
i dont have a manual for it
Old Jan 18, 2010 | 12:24 PM
WifesTRX's Avatar
Default Trx 350
I am having the same problem. I have a Manual and I have run through everything I can think of, I have checked the oil sensor and wiring. I was going to order the starting coil this week. Mine does not spark either. I got it to spark last weekend but when it died I have not had a spark since. Have you come up with anything since your last post?
Old Jan 18, 2010 | 12:55 PM
Helmut1's Avatar
Check the resistance across the stator and check the resistance across the pick up coil. I don't know right off what it should read, but you can find it in a repair manual. If that's not the problem, and you've already tried an ignition coil, then it could possibly be the CDI.
Old Jan 18, 2010 | 01:22 PM
HondaMechanic's Avatar
Old Jan 18, 2010 | 04:26 PM
WifesTRX's Avatar
Default Spark
I believe the Manual states a resistance of a maximum of 10 ohms accross the starting coil. I am picking up 13. I was going to order a new coil this week but then read the earlier post from the gentleman that installed a new one and still has no spark. I did the light meter test on the controller before the coil and got a light so I am getting power up to that point.
Old Dec 19, 2012 | 05:45 PM
Smoothops's Avatar
Hi folks, I'm in the same predicament, no spark. Fuel pump, fuel cutoff relay and 3 CDI units have been tried, no spark. I did the measurements and found a resistance of 1634 ohms across the exciter coil and ground. According to the chart shown in this thread, it should be 50-200 ohms. Also, I could not check the ignition switch as there is no blue/white wire on the CDI terminals. However, when the switch is on, the green neutral light comes on, the oil light sometimes is on, but not all times. I can't hear the fuel pump coming on when I turn the ignition, but when wired directly, the fuel pump works and it looks new. any suggestions?
Old May 12, 2016 | 01:34 PM
lkarulak's Avatar
Default 1987 Honda 350 TRX Foreman
I have the same issue. Changed out the fuel pump, fuel cut relay, sparkplug, fuel filter. Will only start then the sun is out of it's warm out. When you shut it off, no guarantee it will start again.
dirt ryder
Sep 27, 2015 09:22 PM
hondarider1234
Jul 21, 2015 11:53 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
CRamshaw777
Jul 18, 2015 05:46 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
