Kfx 700 problem
Old Aug 28, 2009 | 09:27 PM
Jesse**'s Avatar
Default Kfx 700 problem
Kfx 700 has been sunk and dried out completely, changed oil 6 times and gas treatment to get the water out, but keeps missing when it is first started. It will not miss much and has loads of power like when we first bought it when it gets warmed up but it can't rev up a quarter way when it is first started.
Old Aug 29, 2009 | 11:12 PM
stillV1's Avatar
Not a motor expert by far, but I would guess that the carbs need completely cleaned out. You may need to remove the float bowls and clean any sediment or crap out of them! The dual carbs are a tricky system if they are not cleaned good. Hopefully some of the other technical guys will respond and may have better suggestions as well. Good luck...my son sank his brute and they had to completely clean the carbs!!! I would put new plugs in as well!
Old Aug 30, 2009 | 12:07 AM
rv's Avatar
rv
a little meoh /methonal in the feul may help also to get rid of the water like just a few ounces! if the carbs have a drain on them give then a good drain also and also use some feul treatment that has meoh in it!
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
