250x Timing Chain Replacement
Old Sep 2, 2009 | 01:55 PM
rapple's Avatar
Default 250x Timing Chain Replacement
I think I may have lost the timing chain on my 87 250x. The engine spins freely, but the valvetrain doesn't move. There's also some air escaping from the exhaust when I turn the crankshaft, so I'm pretty sure that the piston is moving.
I have a 300EX shop manual, but the info regarding the timing chain is a bit lacking.
Does the camshaft have to come out to install the new chain, or is there a master link on the timing chain?
Any special tools that anyone can think of that I'll definitely need?
This will be my first major engine surgery so I want to be as prepared as possible.
Thanks in advance for any words of wisdom.
Old Sep 2, 2009 | 02:03 PM
budedm's Avatar
There is no master link so the cam has to come out. That's not hard. But if the chain broke, it could very well be laying on the bottom of the crankcase. I don't know how you can get it out without taking the engine apart. Anyone?
Old Sep 2, 2009 | 03:49 PM
rapple's Avatar
Thanks! I'd assumed that the case cover needed to come off, at least to remove the old chain. I'm more nervous about mucking around with the top end, but I suppose since it's basically dead at this point I don't have much to lose by opening it up and giving it a try.
Old Sep 3, 2009 | 04:05 AM
HondaMechanic's Avatar
If the cam chain broke then I'd be suprized if there isn't more damage when you remove the clutch cover .. The head should be removed and valves checked if your lucky just 2 will be bent , but possibly all 4 are ..
Old Sep 7, 2009 | 10:17 PM
rapple's Avatar
Looks like some good news. I got the valve cover and case cover apart today. The chain is still in one piece. It destroyed the front guide and slipped off of the sprocket on the crankshaft. There's some plastic shrapnel in the bottom of the case, but I haven't found any metal yet, so I guess that's good news.
I think that replacing the guides is more than I'm prepared to tackle, but I found someone local who's done lots of 250x engines and his rates are pretty reasonable. I'm going to disassemble and clean as much as I can to get it ready.
At a minimum, I'll replace the guides and the chain itself since I'm assuming there's a good reason it decided to let loose. I'm also inclined to swap the camshaft bearings too, although the valvetrain looked pretty pristine.
Old Sep 7, 2009 | 11:28 PM
Doctorturbo's Avatar
GOT BOOST!
You need to do a leakdown before you put this thing back together for good.
If this is an interference engine some valves are going to be bent.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
cornermike
May 27, 2015 10:04 PM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
