06Rincon680 HMF utility series question.
Old Sep 2, 2009 | 05:40 PM
Riddick09's Avatar
Default 06Rincon680 HMF utility series question.
I just installed an hmf exhaust. My bike runs fine but the pipe gets hotter then usual. The acctual exhaust stays normal temperature but the pipe that runs from the engine to the exhaust gets really hot. Any ideas of what I need to do to fix it? Or is it ok to leave it the way it is?
thx.
Old Sep 2, 2009 | 11:41 PM
JeffinTD's Avatar
Are you running some sort of fuel programmer?
A free flowing pipe without other modification could be causing it to run lean, which would cause hotter internal engine temps, and exhaust temps.
Old Sep 3, 2009 | 12:14 AM
Riddick09's Avatar
no I am not running any programmers. should I get one installed so they can fix the hot temps? do you think i will have problems with it if i leave it the way it is?
Old Sep 3, 2009 | 05:26 AM
TexasRoadlawyer's Avatar
No Ruts, No Glory
Some answers to these questions would help us...
does your bike have EFI? I can't remember when Big Red started adding EFI.
Is the exhaust pipe stock other than the muffler or is the pipe that's hot an aftermarket piece?
Also, did you do anything else, like add an upgraded filter?
Old Sep 3, 2009 | 06:25 AM
Williebee's Avatar
Post 06 Rincon680 HMF Utility series question.
thx.
Riddick09 i couldn't begin to give you the answer you're looking for without more pacific info about weather your Rincon 680 is Carburated or EFI , but i would deffinitly advice again't riding it in this condition ; as TexasRoadlawyer has stated your engine is running to lean because of the after market pipe (to much air to fuel ratio ) and running the engine could be damaged/blown if it isn't jetted correctly.
Also check your valves specs to ensure they have the proper gap when doing mods to any carbed or EFI engine's , good luck with your ride ; i hope you get it straightened out !
williebee,,.....
Old Sep 3, 2009 | 10:08 AM
JeffinTD's Avatar
06 680 Rincons are a mapped EFI, so they don't really compensate for changes in exhaust/intake restrictions.
Looking at HMF's site, under "recommended jetting" they have suggested settings for Optimizer to compensate for the pipe.
I would absolutely not run the machine as it is. Lean condition can warp exhaust valves and erode the piston.
Old Sep 3, 2009 | 05:21 PM
Sotexy2's Avatar
on my exhaust i have a full HMF on my 250ex, the pipe is hotter than hell! even after just riding it for 5 minutes!! but i took it back to honda thinking that my jetting is messed up but they said it was fine and the jetting is correct...i think its just the pipe itself, im not sure if yours is carb or what not but ask your local dealer mabye
Johnny Mac
60
Dec 14, 2019 06:13 PM
bigred20653
Oct 2, 2015 10:05 AM
cboler9
Sep 24, 2015 08:35 PM
Sep 10, 2015 01:56 AM
Sep 1, 2015 01:45 AM
