2005 700 ?
Old Sep 3, 2009 | 02:16 PM
coco105's Avatar
Default 2005 700 ?
What could be causing my 05 700 not EFI to start idleing around 500-700 rpm and then die. When I give it gas and keep the idle up it seem to be getting hot very fast, the raditor is clean. Any thoughts.
Old Sep 3, 2009 | 03:17 PM
Big600twin's Avatar
Sometimes there are issues with the rubber flange on the carb that gets cracked and can make it run crappy. The overheating may be a seperate issue. Does the fan come on??
Old Sep 3, 2009 | 04:54 PM
coco105's Avatar
Fan is cutting on
Old Sep 3, 2009 | 08:22 PM
Thats the year model on the ecm recall,if you havent replaced it,DO IT before problems really happen! If you have a black finned module under the access panel under headlight pod, then its Chinese and ALL are bad. Replacement is a silver module made in USA. Your local dealer still should be able to warranty! Its main function is charging and fan operation,plus can loose ignition. OPT
Old Sep 4, 2009 | 10:35 AM
coco105's Avatar
I checked and it had the silver ECM.
salixair
Nov 3, 2015 08:25 AM
01ssls1
Sep 22, 2015 06:50 AM
Lou Domenech
Sep 11, 2015 06:35 PM
Brandon400
Sep 5, 2015 08:44 PM
