Mikuni 38mm TMX baseline jetting
Old Sep 7, 2009 | 09:34 AM
bholmes's Avatar
Default Mikuni 38mm TMX baseline jetting
I have a bunch of parts commin for my TB250 and I'm trying to get a consensus on where to start my jetting. I'll be running a cyclone cylinder w/ stock ports (essentially ported reg TB cylinder) with a milled head, HPD pipe and MTQuiet silencer and 20" tires. my carb is/will be a 38mm TMX and running just a clip-on foam filter element. w/o air box. Altituide is about 650-700ft above sea level.
Question is: What jetting do you guys runnin 38mm's on EITHER TB or Scrammys suggest starting with? I'm just trying to get an idea where to start jetting at.
Old Sep 7, 2009 | 11:22 PM
WaaHeHe94's Avatar
Back in 1999 when I first bought my Sport 400 and only had a Hot Seat Pipe, Hot Seat 12-1 billet aluminium head, 38mm TMX, V Force Delta 2 reedcage w/spacer and clamp on K&N filter I was running a 320 main jet at around a 1200' elevation.
Not really sure what a Trailblazer 250 should be jetted at.Your best bet would proabably be to call a company like Hot Seat or Aeen that sells prejetted 38 & 42 TMX's and ask them for their advice.
Old Sep 8, 2009 | 07:07 AM
bholmes's Avatar
Sounds like a plan, thanks for the input. I'll probably have to do that as this post is not getting to many replies.
Old Oct 2, 2009 | 08:09 PM
bholmes's Avatar
for anyone out there searching for the same thing, Aaen was able to help me out on that. Run a 4.0 slide, 25 pilot jet, 270 or 280 (depending on elevation) main jet, and a 6EJ12-58 needle. I used this set up on mine and it runs like a champ
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
