ETC Problem? Possibley?
Old Feb 21, 2001 | 11:24 AM
ForestTrails's Avatar
I have a 1993 350L Completely Stock. about 2500 miles on it.
riding uphill at a steady speed (about 10-15mph)for about 1/2 to 3/4 mile then it starts to sputter untill I move the throttle. then it returns to normal. is this a problem with the Electronic Throttle Control? It runs fine as soon as I move the throttle a couple times.
It has done this for as long as I have had it... Not a real problem worth spending much $$ on but just annoying me.
Anybody have a clue?
Old Feb 21, 2001 | 12:46 PM
Thor's Avatar
Seeing you are from New York, at this time of the year you may have a little bit of frost in your throttle or oil injector cable which is activating the ETC control
Old Feb 21, 2001 | 02:38 PM
RobCulp's Avatar
Does the engine cut out completely or just bog. From what you have described, if it just bogs I think your secondary clutch may require a little TLC!
Old Feb 22, 2001 | 08:19 AM
RobCulp
If I did not move the throttle it would die completely. I am normally climbing a long uphill part of trail riding in low range and only about 1/4 to 1/3 throttle but keeping the throttle in the same place.
Thore
Not frost related... happens summer also... Tuesday was 45°
Quad is parked in a shed.
Old Feb 22, 2001 | 10:03 AM
RobCulp's Avatar
The ETC will act like you shut off the ignition completely. Does it do that and then come to life instantly when you move the throttle or does it go blaah blaah blaah (Bog) when you move the throttle a few times and then pick up and go?
Old Feb 22, 2001 | 10:17 AM
Thor's Avatar
How often do you change spark plugs? Maybe the machine is running rich and loading up?
Old Feb 22, 2001 | 11:09 AM
RobCulp...
Yes it acts just like the ignition switch was turned off. and yes comes back instantly when I move the throttle.
Thor...
Original Plug... Never changed... probibley could change it to new but looks fine. not rich or lean...
Old Feb 22, 2001 | 12:54 PM
RobCulp's Avatar
Could be ETC then but it should happen all the time, not only on hills, that doesn't make sense.
Old Feb 22, 2001 | 02:00 PM
Could be that climbing this long hill is the only part of the normal ride where I am not moving the throttle faster or slower for any length of time. it does not happen untill the throttle is in the same position for 60 seconds or so...
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
