Kawasaki Mojave Problems
Old Sep 11, 2009 | 10:26 PM
Mojaveman48's Avatar
Default Kawasaki Mojave Problems
Hello i was resently out riding my mojave and it started bogging and backfireing when i would accelerate it will start fine and idle a little ruff and high so i tryed adjusting the air mixture screw and now it got worse and now it has no power i will drive it up the street and it will bogg and cut in and out and it back fires really really loud i had the nabor yell at me saying that i was driving his dog nuts but it will not stall it just boggs down and loses power when you rasie the throttle above idle and today while i was playing around with it i found out that it runs like it is brand new when i run it with full choke it revs up with no misses cuts or backfiring but i thought if it runs good with the choke on that means that its running to lean im guessing but i played with that little damn screw all day and no matter how much i turned it or what direction i turned it it wouldnt make a difference so let me know what you guys think im up for anything because i was playing on going riding this weekend so let me know what you think i should Thanks
Old Sep 12, 2009 | 08:01 AM
1mojave03's Avatar
Hey, I have an 03 Mojave. I'm just wondering if your fuel shut off packings are shot. What year is your mojave? Try to drain the the carb via the drain screw and note if any dirt or debris is present. It sounds like a fuel delivery problem for sure. Post back what you find.
Old Sep 12, 2009 | 08:26 AM
my mojave is a 94 and what do you mean by fuel packings i drained the carb bowl and just gas came out that i could see
Old Sep 12, 2009 | 08:37 AM
1mojave03's Avatar
Hi, sorry... I mean on your fuel shut off valve. Just a thought.
Old Sep 12, 2009 | 08:50 AM
no no i just domt understand what you mean by fuel packings are you talking about the gas filters in the tank or something with the valve
Old Sep 12, 2009 | 09:52 AM
1mojave03's Avatar
Yeah, I mean the valve on your tank, but I don't think there are any filters. Sometimes the packings go bad esp. on a 1994 machine. Just a thought. Do you have a way of checking the coil? Do you have the repair manual?
Old Sep 12, 2009 | 10:31 AM
yea i have a repair manual its a clymer manual and no i dont have a way to check the coil but i think it is a carb problem because about an hour ago i was out riding it and it started up second kick at full choke i let it warm up a bit turned the choke off and it was idleing nice so then i drove it up the street and it had no power it just backfired and sputterd so then i put it a full choke and drove it up the street again and it had a lot of power and no bogging or backfireing
Old Sep 12, 2009 | 10:43 AM
1mojave03's Avatar
Oh,.. ok.. sounds like the needle and seat are stuck or worn. Or the float is screwed up.. might be time for a complete carb rebuild, should cure the problem. Has the carb ever been rebuilt? A good cleaning should make a world of diffrence. Good luck with it and post back how you make out. Oh btw the carb is pretty easy to remove when you have the book.
Old Sep 13, 2009 | 07:39 PM
ok so today i took the carb off and disasembled it and it seem really clean but i cleaned it anyway so i sprayed everything with carb cleaner and then blew everything out with compressed air then it put it all back together put fresh gas in the tank straight from the pump and fired it up it started up no problem and idled fine but i still can rev it up with out it have a problem it still boggs but when i put the choke at full it runs just like it should
Old Sep 13, 2009 | 07:41 PM
oh and by the way i did rebuild the carb i would say maybe 20 hours on it or some where close to that how often are you supose to rebuild them
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
JoAnnS
Jul 23, 2015 02:18 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
