Hummmmmm
Old Sep 12, 2009 | 10:19 AM
dunekrew's Avatar
Default Hummmmmm
This might sound nuts but I just installed new Piaa H6M bulbs on my 07 DS650X and now the low beam high beam is reversed. Can anyone tell the fix for this?
Old Sep 15, 2009 | 10:12 AM
DuneRider650's Avatar
I ride a little here and there......
no idea how that would happen unless you put the plug on backwards or something.....onlyway to fix that IF the bulb is actually the problem would be to cut and switch the wires around on the back of the connectors..... wouldnt do it
Old Sep 15, 2009 | 01:40 PM
dunekrew's Avatar
I’m as baffled as you on that one, but I did pull the wire and reconnect so now it works right. Do you know the stock wattage on the Baja bulbs I’m looking at the Piaa H-3 super white to match the main bulbs and all I can find is the 35/70 or 35/60 watt bulbs?
Old Sep 15, 2009 | 05:07 PM
I believe the stock wattage on those were 35 watts i upgraded mine to 55 watt Silverstars with AWESOME results
Old Sep 16, 2009 | 07:07 PM
dunekrew's Avatar
Will know this weekend, going to pull the stcok bulbs how much did the Silverstars cost you? Piaa are going for $26.00 a bulb on the baja and $32.00 on the main
Old Sep 17, 2009 | 09:52 AM
right around 18 a piece
