2000 Kawasaki Lakota- tapping/clicking noise
I have a tapping/clicking noise coming from the right side of the engine. It sounds like it is coming from the lower end of motor, but it is hard to tell. I have adjusted the valve clearance, so I know it is not coming from there. The engine starts quick and idles/runs smooth, just as it should. The sound is consistant at all levels of rpm. It has a self tensioner on the timing belt-has anyone ever had one go bad or come loose? Not sure this is the problem either. Any suggestions? Thanks. Dave
Thanks. Was your timing chain making a slapping noise or more of a tapping? It sounds like rocker tapping but I know the valve clearance is correct. I don't mind changing out the timing chain. Thanks!
MeadowlarkFarm
Nov 27, 2019 08:40 PM
