EFI addons question
Old Sep 13, 2009 | 08:10 AM
tehpwnerer19's Avatar
Default EFI addons question
If I have an EFI machine, and buy aftermarket addons such as intake and exhaust, there is no carb to rejet so do I just plug and play or does something need to be done to the EFI? Or does the EFI just compensate automatically? Thanks.
Old Sep 13, 2009 | 08:17 AM
95wolv's Avatar
EFI is designed to compensate for altitude and temperature, if you just replaced the stock air filter with an aftermarket filter,without modding the lid or adding holes, it should be fine. Some are set up to handle aftermarket exhaust if the ECU is "told" it has to add fuel. A lot of the time, you need to buy an aftermarket "fuel commander" that will remap the fuel output to match your mods.
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
